g40 seat question
hi guys.as above my passenger seat seems to be twisted/bent a bit so wondering what do i have do to remove the cover and fix it? thanks Baz.
Edited by barrys17
bump. anyone?
which part is bent? I'd have thought the best way would be to get another seat from a mk3 polo (you'll need to look for a height adjustable one if you still want that) and swap the foam & material over. I think the material is mainly clipped on with metal clips you'll need to unbend. I know people have replaced the foam in seats when the sides have collapsed before so it is DIY-able. If the actual tubular base is bent I doubt it'll be very easy to straighten out.
p.s. you can separate the back from the base so it'd just be a case of swapping that part over.
if its the bottom part (arse bit) then i have a spare and easy to swap. i think the top part is more involved
sorry should have stated its the upright(back)part of the seat..i'm guessing there must have been a few people squished into the front or something..its puzzling. may take a stab at disassembling it tomorrow.thanks for the help. Baz
