Painting Help! Lacquer
Hi guys i am respraying my wing myself, its black and the colour coats have gone on, the question i have is that how do i get the deep shine after putting on the clear coats? I've put on a put maybe 2 or 3 light clear coats but its not shining, any help would greatly be appreciated.
  • Replies 10
  • Views 1.5k
bmp
sounds like your not srpaying enough on , you idealy need to heap it on fairly heavy but not so bad it runs
if you get enough on , you can always wet sand it and buff it up
Will 1200 wet and dry make t shine?
1200 is a bit harsh.
try tcut or an abrasive polish :-)
ok so to be clear, lacquer it, then use an abrasive polish on top to give it a shine?
You need to put it on wetter, but as said avoid a run.
To get the final finish you want to flat with 2000 wet n dry then polish back with an abresive polish, think some of the cheaper ones like 3M finesse are available to the none trade.
T-cut isnt the right product to finish the wing off with though.
as has already been said and its the way i do it too, get plenty of coats of laquer on (the more the better) then give plenty of drying time so the laquer has hardened, then very lightly wet sand with 2000 grit, then dry and it will have a cloudy finish so polish it up with a good quality polish and it will shine like a good un'
craig
yeah let it sit for week after youve put plenty on
gentle wet sand with 1500/2000 then polish it up
wet flat with 2000 wet and dry and then machine polish
ok thanks to everyone appreciate it
