Anyone retro-fitted climate control to a 6n2?
Has anyone fitted climate control from a 6n2 gti to a base model/tdi? Guessing it's a lot of hassle, if possible but heard of people fitting A/C to mk4's. Thanks very much
  • Views 2.7k
it's very possible, in fact it's easy but it's a lot of work.
do you want the full climate with air con or just a non air con climate system ?
Ideally, i'd want the full lot with air-con, but i'm sure its a right pain! Have you done it? Cheers
I've put air con in cars and also converted cars over to climatronic.
Could you tell me what each setup requires? Thanks very much
