help
right I'm going to de badge the polo and get rid of the bumpstrips on my 6n but I'm not sure what they are held on by , and how would i go about doing it
cheers jake :-D
  • Replies 8
  • Views 1.4k
rear badges are glued so use hair dryer and something to remove the lettering (i used an ice scraper and snapped the lettering on my 6n2)(and some T-CUT to remove faded paint)
not sure about the bump strips, not tried that...
and i'm Jake too...
Edited by Duey
cheers mate much apricated .
you can do it without a hair dryer but it's easier with.
i also used lots of label/sticky stuff remover (halfrauds special!) after i'd removed the badges to help remove the glue residue.
i've also heard of people using "caramel wheel"s but i have no idea what they are or how to use one
ebay 'fudge wheeeeeel", never use an ice scraper if you actually care about your paintwork
solvents and the likes are useless as it is just not designed for the job
i didn't press into the paint and lubed it with the label remover stuff. small, light movements and it came off eventually with a few ultra-light scratches which T-CUTted out when i T-CUTted it to remove faded paint
just Ebay Uk'ed Fudge wheel and only got sweets :?
Edited by Duey
The bumper strips are usually just held on by a sticky strip (at least mine are anyway) so they'll come off pretty easy is you just slowly peel it away from the car.
Ruth
i got the badges off easily with my 02 top up card and T-CUT , cheers people
