PIONEER AVH-P7500DVD
in fully working order
350 pound open to offers
to find out more you can call me on: 07891086090.
You won't believe your eyes until you see it, hear it…and touch it. This multichannel DVD AV headunit, the star of Pioneer in-car entertainment, combines everything you want in the world of audio and visual: a sleek wide-screen 7-inch high-quality touch panel display, a high performance D4Q digital tuner, a MOSFET 5 x 50 W amp and DVD player.
Operation of the AVH-P7500DVD is unbelievably fast and simple, thanks to its touch panel display complete with an exciting new GUI (Graphical User Interface). You control your audio, video and navigation settings with the touch of your finger.
The ultra-slim built-in DVD player is compatible with all the latest digitally encoded discs, including high fidelity DVD-Audio for the audiophiles. Cinema fans will be stunned by the realistic cinematic soundtracks emerging from the 5.1 channels, courtesy of the Dolby Digital/DTS/Dolby Pro Logic II decoders.
The built-in DSP (Digital Signal Processor) lets you customise your sound system to your taste with the Pioneer exclusive Multi-channel Auto EQ and Automatic Time Alignment.
The IP-Bus connection means you can easily hook up extras like a TV tuner, DAB tuner or multi-CD player. Whether you want a great stand-alone AV system or a perfect addition to your Pioneer AVIC Cyber Navi unit, this compact AV headunit is the answer to your quest for the ideal in-car entertainment.
Specifications
Key features AVH-P7500DVD
Fully Motorised Touch Panel Display
Built-in DSP with Auto EQ and Automatic Time Alignment
MP3, CD, DVD-Audio/Video Playback
Dolby Digital / DTS / Dolby Pro Logic II
Dual zone operation with front Video and rear AV output
Back-up camera input
D4Q Digital AM/FM tuner
6-channel Hi-Volt (5V) Pre-Outs
General AVH-P7500DVD
Amplifier MOSFET 50W x 5
Equaliser EEQ+ Equaliser with HPF, LPF & SFEQ
Built-in AM/FM RDS Tuner D4Q+
DVD Capabilities DVD-Video/Video CD/MP3 CD player
5.1-channel surround sound capability:
- Built-in Linear PCM/MPEG-A/DTS/Dolby Digital/Dolby Pro Logic II decoder
- 6-channel DAC & 6-channel DSP
- Digital Sound Field Control (SFC) for multi-channel sources (Musical/Drama/Action/5D Theatre)
DVD-Audio/DVD-Video/Video CD Playback with Direct Search Chapter/Track,Next/Previous Chapter/Track, Fast forward/reverse, Pause, Track/Chapter Repeat, Condition Memory (30 discs), Play back Control (Video CD only), Direct Search Title/Group, Time Direct Search, Scan, Digital Direct
CD Capabilities CD Playback with Track Scan/Pause/Repeat, Random Play, CD Text, List Search MP3/CD-R/RW/CD-ROM, Random Play
96 KHz/24-bit DAC
24-bit D/A Converter
Track Search/Scan/Repeat
Track/Manual search
Last position memory
Disc Title Memory
Source Control MCD, SCD, TV DVD, DAB Tuner
Control via front panel buttons or Remote
Voice Guidance When connected to Pioneer Navigation System
Display type Wide Screen TFT active matrix LCD Color Display
Touch Panel Operation Yes
Display size 7,0 Inch
Screen Coating High quality anti-Glare, Low-Reflection coating
Installation possibilities In-Dash
Fully motorised display with auto dimmer with free adjustable viewing angle (50 - 110°)
Front panel Removable with safety warning beep
Selectable wide screen modes Just / Full / Cinema / Zoom / Normal
Rear camera switching Yes
Remote Control Included
D/A Convertor 24-bit
DVD - R/RW and CD - R/RW Playback Yes
Built-in MPEG 2/1 decoder Yes
DVD video player Yes
Region number 1
Connections AVH-P7500DVD
AV Output 6-channel Hi-Volt (5V) RCA Pre-outs (FL+FR+RL+RR+Center+SW)
AV inputs 1 RCA
AV Bus Input Yes
Input for rear camera Yes
RGB input for Navigation System yes
IP Bus input Yes
Rear monitor output Yes
Edited by elie_n
  • Views 770
needs a price
Bump
bump
