My Mars Red Breadvan
Sounds like a massive air leak, get the car to someone who knows what they're doing and you'll never regret it.
  • Replies 142
  • Views 30.7k
  • Yeh this thread is still going Iv just been taking too long with it and not enough time now days to work on the car .the AEE is an easy fit yeh couple of small things u gota do there's a guide on here
  • Sounds good buddy, I'll have to have a further look into it Sent from my iPhone using Tapatalk
Yeh thats the hole problem getting it some where
  • 10 months later...
Update . cars been off the road now for so long ,so the bike carbs are off now SU carbs are ready to go on had a manifold made up by my dad so it hasnt really cost me much so thought it was werth ago , should look good once polished up.
4847C7D6-6E33-4F24-B885-CE785A317B8E-131
32BCCD9A-F465-45A9-AB98-3601E3B82764-624
That's certainly different. Will be interested to see what performance is like with them!
  • 1 year later...
So its been a while but finally got the polo back out the garage and mot'd still have running issues with the SU carbs same as when i had the bike carbs on drives fine but if u put you are foot down its chokes and dies so same problem as i had before and seems to run on 3 cylinders till its warmed up also .
Hi Ryan is there any new pics of the old girl. Great to see you still have her
Dont know how I haven't seen this thread before, the setup looks cool and I've never seen SU carbs on on e before either. I hope you sort out the carbs and get it running right, be good to hear a comparison to bike carbs
  • 4 months later...
Dropped another Aee engine in the other week due to low compression of the old one still got to wire it all back up but hope this one runs on all 4 cylinders properly .
  • 4 months later...
So the second aee is in and it's solid engine this time round .iv dropped the su carbs and now in the process of fitting a gt loom to make a 1.6 gt .iv brought a manifold that's been welded up to fit already so it should be a case of plug and play and hopefully get a reliable set up .
Not sure if this thread is still going, but I've been reading it all, and seemed to notice that it looks like the AEE just fits straight in with no mods, am i right or wrong, this would be a perfect conversion for me
Yeh this thread is still going Iv just been taking too long with it and not enough time now days to work on the car .the AEE is an easy fit yeh couple of small things u gota do there's a guide on here somewhere .I'm doing my last bits now with the gt loom all I need to do really is mount the pump and filter .
Just need to wire up the fuel pump n plumb it in then im almost ready the fire her up .
Just need to connect the fuel lines now
  • 7 months later...
Long time since update, replaced fuel lines with coper nickel pipe and after an attempt to fire her up i realised iv plumbed in the fuel pump the wrong way round so no fuel getting to the injectors.
Now all changed round the right way and iv got fuel spark and injectors are tested and working .
After another try firing her up she caughs n splutters so im close now just need to sort the timing out properly seems like none of the marks line up when put in to tdc position on the cambelt side of things and ignition seems like its 180 degrees out so not sure what to do now.
Update ,timing was all fine shes fires up n ticks over nicely once warm tho i have a problem with cylinder 1 or an airleak on the manifold on that cylinder so il be replacing the gasket and using sealant first .
So iv replaced the inlet mani gasket and also now using studs and nuts instead of bolts the attach the mani seems to do up tighter and had sealed better , now have no smokey exhaust and poping has stopped ticks over nicely now . Im waiting on a rubber grommit so throttle cable to be attached properly then hopefully i can sort out and mot n get her back on the road finally.
