1.3 Kent 300deg Cam - Mechanical Head
Kent 300 Degree high lift camshaft.
Still in box and bag.
BRAND NEW
Basically impossible to get hold of these days.
Will ONLY fit 1.3 mechanical heads in pre 90's mk2's, mk1's and polos.
Will bring more power all the way up to 6.5/7k and perfect to use with twin 40's or bike carbs.
£200 ono.
Edited by roger@northernedition
  • Replies 17
  • Views 940
TTT
If your engine doesn't look like this :
It will NOT fit.
impossible 2 get hold of indeed. just selling my mk2 atm, this would have been perfect, but i no longer need mechanical cam. anyone with a mk1/2 polo or mk1 golf 1.3 should snap this right up. free bump
Do you have the valve lift figures inlet/exhaust in mm?
Does it need piston pocketing.
From the spec sheet :
P03 - Rally spec cam (Highest 1300) -
Power band 2500-6500
40/80 80/40 timing figures
10.40mm valve lift
300deg duration
Valve clearance inlet : 0.35mm exhaust : 0.045mm
Full lift @ 110degrees
Cam follower : Not required
Valve spring : Not required (But I know you can use 8v double springs if you wanted to)
From what I've gathered from Kent, no alterations are "needed" obviously uprated springs & a vernier would help maximise the effects.
Hope that helps.
TTT
Have you still got this dude?
And just to confirm that it will go on a 1.3 gt?
Got cash and can collect.
Cheers,
Martyn
Provisionally Sold awaiting payment.
If sale falls through : as said above - it will only fit your 1.3 engine if it looks like the one above. Mechanical Lifters ONLY.
  • 4 months later...
did this sell after?
unfortunately yeah it did, I PM'd him back then.
shame, would of loved to of had this on my coupe
i do though i cant remember them but basically i mesured a standard spi cam the mk2 gt cam which was an EXTRA 3.6 mm or there abouts longer on the stroke ans the kent was only 0.2 mm longer then the gt
It will NOT fit.
What airbox is that from?
its from the german mk2 gt coupe.
is this still for sale?
nope
me too i cant find anything to tune my coupe
