Best way to smooth seams under rear lights
Done a search as I know there's a thread but I cannot find it! What would be best way as the area is rusted up so I will be grinding it back to bare metal and filling it! Is it better to put bits of weld down the seam? Or will fiberglass cellulose stopper or filler work?
  • Replies 10
  • Views 1.5k
i was reading an article on a car in PVW a few months back...and the chap scraped all the sealer out and brazed the joint up, flatted back and filled over the top of it.
i spose to make it stronger as its a joint.
tbh, id like to know the best way of doing it aswell as I'm thinking of doing it when i have the arches off later this year.
Its there for a reason, for water to drain down.
If its not there the water will sit under the light, we all know what happens next ;)
brazed?? what does this mean sorry! lol
so how would i go about repairing the area then whilst keepin the seam, as id have to get all the sealer out to remove rust behind it aswell!? what sealer to use? wont the water drain away anyways eventually, will it make that much difference?
brazing/welding is the best thing to do then skim over with filler
the thing about it being there for water to drain down is bullsh1t, theres loads of cars without it
theres few ways you can do it
lead loading
brazing
weld
filler
depends ont what you want to do it all works . all would say is make sure you kill the rust
thats what i thought, I'm not too clever with the old welder i can give it ago but i think ill ask the old man to do it for me while he does my sill plate and spare wheel recess! cheers guys
filler would surely crack no??
what about chemical metal??
Edited by Pepe
brazing is the same as welding, but instead of joining metal...it is used as a filler metal [correct me if I'm wrong]
if you repaired the area, id say seam sealer would be the best thing to use to reseal it.
when I'm sealing at work [this might sound gross] i spit on my finger and lightly glide my finger over the sealer to make it smooth.
yep the spit on the finger works a treat it tasts nasty
Edited by gazz
weld it then a skim of filler
don't just fill it, it will crack, seen it on a local lads car, it cracked after less than a week
