Rear Rattle
As title says - Fitted coilovers a week or 2 ago, and I've just noticed a small rattle from Passenger side.
It sounds as if it could be coming from the Top mount area.
Just wondering if anyone had any similar experiences and what the cause was?
I Think I will take the strut off and check grease the top mount area?
  • Views 1.2k
Mine does this, Just turn your music up ;)
Seriouse note: I would like to know what it is also :paranoid:
I've got a list of things it could be, But dont want to have to go through them all.
Rear Foldable seat rattle
Rear interior body panel rattle
Interior Boot rattle
Topmount issue
Bottom of the strut needs greasing (unlikely because it would be a creak)
Mounting of strut to topmount not tight enough
EFFORTT :(
adding to your list...
rear light cluster.
i have a rattle from the rear on the drivers side but it seems to have gone away on its own now, squeak was located in the plastic roof bit above the rear bench.
also are you sure its from the rear? i had another squeak which i thought was coming from the rear but it was my front anti-roll bar! bit of copper grease solved that one!
Edited by nick0323
Might have found it!
Crawling and jumping around in the boot this morning.
Topmount nut on the strut wasnt done up as tight as possible, Hopefully it doesnt re-occur
You should really keep children in baby seats, not the boot.
Tell me about it, I completely forgot I left it in there (With its rattle) :biggrin:
