replacing roof lining
when i got my polo pretty much every thing including the roof lining had been stripped out, this really ain't my cup of tea so whats involved in refiting another one? Are they just glued to the roof in certain places?
I've been offerd one from a bready thats being broken but are they difficult to remove without damaging them? Any tips on how to do it?
  • Views 2.2k
i know its not the same car, but in my 6n2 is literally only the grab handles/pillars/rubber door surrounds/sun visors/interior light that hold the liner up!
woulda thought yours would be the same?
Edited by StreetBassScott
It's no where near as solid as a 6n2, it's litteraly a bit of fabric
I've not had mine out fully, but as soon as the visors came out it was floppy as feck!
it's really easy to remove the liner. if it's in good condition in the car your getting it from you can remove it using a flatblade screwdriver.
all sounds good so far don't it!......
well here's where it gets crap - u need to remove the windscreen and 1/4 windows to get it out!
I made a new lining guy and all you need is a seeing machine and a roll of cloth.... or leather;-)
held in with metal rods sprug into the roof and then glued around all the window surrounds, its do - able but neds a bit of patience and all you windows out
sounds pretty straight foward, i need to fit a new windscreen and give the paint a blow over so i will have to take the windows out any way.
What sort of glue is best to use when refitting it?
i used a spray glue bought from a carpet shop. worked a treat mate. you need to go to the market aswell and buy some pegs, as you will need to hold the liner folded over the seams and using pegs i found was the best method!
top tip! Cheers mate :thumbsup:
