Coilover problem
Okay I tried to fit my rear coilovers the other day and came across a slight problem, when i attached them at the bottom and jack the arm up so that it goes through the hole I don't seem to get enough of the bolt coming through I've tried letting the springs right down and jacking the arm up as far as i can but it doesn't seem to want to give, if I don't add the rubber bush piece it fits fine but with the rubber bit I cant force it to come through far enough to add the top nut.
Please help
roo
Please help
roo
Right, i had this problem when fitting my Jom coilovers.
There was a metal tube thing bit fitted here >>>
and i was supplied with smaller ones, swaped them over and they were then fine.
Check for that. Hope this helps
Pete
sweet same coilovers and i was wondering how did you get the shorter parts? and this si for a 6n2 yeah?
double post sorry :/ but how long were these spare peices?? or was it the bit that is just on the top of that plate peice and then theres a bolt ontop of that :)
wrong section
