Fast Polo?
http://cgi.ebay.de/VW-Polo-2-1L-Turbo-Komp...=item414fe2ece5
Pretty freaking mental
(Bad babelfish translation)
To the sale here a Polo 2F 2.1l turbo/compressor all wheel stands
Engine:
Particularly adapted 1Z engine mount bored on 82,5mm and adapted for broad piston rods.
Forging piston of company Wössner particularly works on.
Steel piston rod special production of INT engineering for dragee Racing.
Crankshaft 1Z nitrates
Racing oil pump with large Fördervolumen.
Block reinforcement plate made of high-grade steel 10mm special production for large 1Z crankshaft and broad piston rods
Cylinder head basis 20V Sauger with widened and smoothed in and discharge opening channels.
Cylinder head channels adapted on 1Z block.
Inconel of in and exhaust valves with titanium spring discs and strengthened feathers/springs.
Special hydraulic tappets for increased numbers of revolutions.
Number of revolutions celebration to 8500 rpm
Specialmade sucking in bridge with funnels and 76mm on the inside butterfly valve.
Siemens 900ccm injection nozzles at 3 bar.
Self-'s building crank case exhaust for very large Fördervolumen with double chamber filtering
Impact loading elbow union special production with RS2 Wastegate.
In sucking in (100mm) is a transfer valve, which switches automatically between compressor and turbo-loading.
The change-over takes place flowing! One does not even see the transition on the performance diagram, which often represented a large problem with similar changes.
The compressor is a Eaton M64 and over an additional wave by means of toothed belts is propelled.
Compressor enterprise can be switched off by means of toothed belts and the quick release fastener.
Save GT35R turbocharger with 82A/R exhaust housing and High flow compressor side.
Large Frontmount intercooler.
The load air lines run ever more largely becoming up to the butterfly valve.
Forge 40mm Pop off.
Exhaust system completely high-grade steel 76mm with ESD and bypass flap.
Thus can be switched also to 76mm continuous.
K&N air cleaner with 240x180mm.
Bosch Rennsportsprittpumpe
AUDI S8 90mm air mass measurer
Motronic from AUDI TT with E-gas.
Completely adapted wiring harness.
Drive:
DQB 6 course Quattro transmission with strengthened Winkeltrieb with universal joint. (Thus no more problems with Hardischeibe)
Change on rigid gear operation without play.
Sinter metal full PAD clutch and strengthened pressure plate.
Fidanza aluminum flywheel.
4 special made strengthened drive shafts.
Haldex rear axle differential with internally developed control.
Change-over between auto and hand mode.
In the rough one explains:
Car: Freely adjustable one proportional all wheel distribution by driving speed.
Hand: Freely adjustable one proportional all wheel distribution by drivers.
Everything over display and keys adjustable.
Acceleration measurement for 3 adjustable speeds selectablly.
Safety functions are as available with the original control further (e.g. when braking).
And still a few small further functions:
Strengthened ensures engine haven front suspension struts and in the back with thread chassis.
Brake assembly of G60 in the back of S3 both axles ventilates in front.
Light alloy wheels extra easily ATS 15 " 205/50 R15.
Karroserie:
Basis of the front's building forms the salt man framework, which was converted however accordingly.
Thus are in front triangle steering wheels with university ball joints.
The body seams were after-welded.
The tunnel was adapted for the cardan shaft.
The rear axle is based on AUDI TT a Quattro rear axle with completely adjustable props (trace/fall).
The tail was converted accordingly for the admission of the rear axle.
The body was radiated before at the beginning of the body work and again sealed.
Wheel arches all around gulf 1 widens.
The car looks from downside like if everything off the line would have come in such a way, convinces themselves it.
Intereur:
AUDI S3 Tacho
Haigo full cage
Cathedral props in front and in the back.
Bowl seats with H-belts
Similar announcements for load printing, water temperature, oil pressure, gasoline printing.
Digital announcement for Abgaßtemperatur, oil temperature.
Battery in the tail with emergency stop switch.
Further details:
Before the change on all wheel some things were already registered. (Engine, front axle, Intereur etc. )
By a short examination of the TÜV `s during the all wheel change nothing stands to an entry of the whole one in the way.
Only the noise backdrop of the compressor would have to be dammed, and possible little things.
In this vehicle one e.g. does not find Austattung like radio and other unnecessary weight.
By the turbo in interaction with the compressor the vehicle is suitable ideally for acceleration or mountain running, since generally speaking number of revolutions volume achievement and torque lines up!
At present unfortunately the Schaltturm is in the transmission defective, it is permament the second course inserted.
By exchanges of the tower or replacing the transmission the vehicle is again complete drivingready.
It can be talked however to still make.
Test run nevertheless possible, but only with serious-meant prospective customers.
The vehicle is co-ordinated at present only to 6400u/min (for the first tests).
The vote took place with the bosch service Henni GmbH sews Stuttgart.
It has already with 6400u/min and 1,9Bar load printing an achievement of 500PS and 550nm, considers you also the enormous torque in the lower speed range.
If one continues to raise the number of revolutions, then also a higher achievement is possible. (600PS no problem, see to performance diagram - > no sloping load printing curve still long)
Technical data:
82,5mm drilling
95,5mm stroke
2.1L Hubraumm
Compression 8,3:1
Unloaded weight: 1020kg
0-100 approx. 4sec and 1/4 mile time with present 205/50 R15 road tyre 11,2sec (4 revving up wheels on the first 70m)
  • Replies 25
  • Views 3.3k
oh my god with that bay you could get away with any stupid wing mirrors and front bumper
Edited by richhasbigtits
wow, almost worth a trip to germany to pick that up :shock:
^^ thats what i was thinking, i really want that but I know nothing about importing cars lol
I'm thinking now may be the time to learn! 8-)
what a beast
Ha thats mental...
i would keep the outside looking absolutely stock, even get granny beads on the seats. take them by surprise!
Drive it back.
500bhp and just over a ton, that'd be fun. I swear 1z engines are diesels though??
holy shit at the video's
Autobahns. Hello :)
With the turbo where it is, you're sure gonna here that thing spool up.
I'd love it. Anyone wanna buy my G? :lol:
WOW!!!!!!!!!!!!!!!! :shock:
they are the TDI lumps found in mk3 golfs ect from the mid 90's, but that looks like a 20vt lump to me :?
maybe it's like the people that use the small block seat diesel bottom end's on G40's as an upgrade?
It says it has a adapted 20v head, so its a right little hybrid. Looks fapping mental though!
The 1Z is a diesel, it's the first TDI available in a golf.
You could bolt a 20V head up to it easily enough if you mess with the channels as this guy has.
It's an interesting combo.
:drool: that is freaking shhweeet
Edited by dub17
Higher power:weight ratio than a Veyron. And in a car that's fun to drive with a 1.3 in it. That should be quite something to drive.
OMFG =D i love it!!!!!!!!!!!!!!!!! the sound of that engine is lush as!!!!!!!!!
i think the age of low and slow just went flying out of that cars back box
WOW fucking insane!
Autobahns. Hello :)
i might!!!! :lol: (buy the g that is lol )
that is sex!!!!!
my mate has a scapso west coast with a flashing gear knob and a 16v sticker on the back so i know my mates saxo would beat it
Aye that'll be fun, but this polo just needs wings :badgrin:
Autobahns. Hello :)
Its at 5000euros at the min. Proper bargain ;)
One thing i dont like though is the placement of the frame foot on the drivers side (see pic)
In an accident, surely that would punch straight through the floor ?
