Lightening
Finking bout lightening my mk2 a lil. Wanted to kw what thickness perspex would be best to use for the windows?? how easy is it to cut?? also going to cut the spare wheel well out and get a carbon fibre cover same with the sun roof. Carbon fibre mirror, Remove heating system, full interior except dash, sum lighter seats.
  • Views 741
You dont save that much on glass if you want to be able to open the door windows,and you can punch the panel out unless its riveted into place. I used 3mm thick Bayer Macrolon polycarbonate,but I'm back to glass now. If you dont mind sliders for your Maccy Dees then removing the winder mechanism is half the weight gone,next to which transparent material to use (acrylic is brittle but has relatively good scratchproof properties,polycarbonate is most impact resistant by 80x glass,it'll fold if you're 'ard enough).
The heater is handy all year around,even with the fan off it helps keep your breath steaming the glass up.
There's a little weight in the motor and a good litre of water for the matrix/pipes but its otherwise all plastic. If you must take them out id at least advise you leave the featherweight box in with the shutters,so you can have it open or closed.
Seats are a big factor. The fronts are heavy,particularly the height adjustable one on the drivers side,some buckets can save a nice weight.
Later side impact doors are heavier.
Spare/jack/tools are heavy. Good 15kgs there.
There's a good 7kgs to be saved by swapping your 5sp gearbox for a 4sp one.
MK2F - The steel bolt-on crossmember under the radiator can be swapped for a suitable extruded aluminium item.
Take to parking on hills,and you can dump the battery and starter motor. Major weight saving there. Bit embarrassing at petrol stations,though (carb'd cars only).
Aluminium cylinder block. Weight saving depends on the rest of the engine (it wont remain 1272cc),but will be over 15kgs minimum saving.
Small carbon fibre parts are just going to be expensive without achieving much. Aluminium is perfectly suitable for replacing the spare wheel well.
All sound insulation matting. Its a bastard to remove but it all adds up to weight worth scraping out.
Rear wiper,you already know about. As with alloys,and not too big with the tyres. Unless you fill em with helium..
