6n2 rear bumper removal - help!
I'm stuck! need to get the rear bumper off my 6n2 gti and I've removed all the screws from the rear arches and the two underneath the bumper aswell as the two in the boot shut panel but it doesnt want to come off? am i missing something? where do i go from here!?
your help is much appreciated! thanks
  • Views 3.1k
Popular Days
Hope I am not too late ...
Had to do this yesterday to fit towbar..Like you bumper would not pull off..Heres what I did..
Undo all bumper bolts like you say..
Then undo the four nuts holding inner metal bumper and remove it ,it comes out quiet easily..
You will now see four black plastic fittings with a 10mm hex on the end use small socket or spanner and undo..
They are push on but they dont seem to pull off..I tried levering them but gave up because I thought the plastic bumper was going to break.
I put some silicone grease on studs before refitting to make it easier next time.
Good luck.
