First Time at Spraying
Okay, so i'm planning on respraying my car at some point in the next couple of months.
The bodywork is shite on my car, okayish on one side but the other has a rather large battle scar from an accident i had in March last year.
I picked up a wing and door on saturday and wanted to test out the paint and experiment to see what sort of finish i could get.
please understand that i have never really sprayed before other than the odd badge etc
So i rubbed back the wing with a course wet and dry, cleaned and got rid of all dust.
Then first coat of primer
I then used a fine wet and dry to get some imperfections and then today finished two more coats
I'm really happy with the finish so far going to test the color out tomorrow but i think after using the course paper before the first coat i maybe should have used a medium to smooth it a bit more.
Any help or tips would be fantastic. What do'you think?
cheers, George
  • Replies 22
  • Views 2.7k
a few comments..
once your done priming , dust over some dark colour like matt black , that acts as a guide coat so you can see where youve flatted
id let the primer sit at least a week so its nicely dried out ...then wet sand it with 800 , until the guide coat is gone
a few comments..
The colour is matt finish anyway, does that make any difference???
No, just dust black over very lightly, so that theres just specs or black, a bit like overspray really, and then as you flat it back you can see which bits need more work, as the black will come off the high areas first.
Oh i see, between coats of primer do you need it to be wet with sandpaper or does it not matter?
I think when i do the whole car i will use and electric sander, other than the fiddley areas lol.
Use some fine wet and dry, make sure its wet though between coats. When you are doing the whole car, you may not need to rub the whole car down with sandpaper. On areas with no imperfections, you can get away with using scotchbrite and a rubbing compound.
that looks really good mate. 8-)
always been scared of trying body work on big panels.
just take your time and it should look ace.
Look good mate for 1st attempt, I'm going to really have to start this also id love to respray my own car :)
DO NOT use a scotch and rubbing compound as it will leave a film on the surface and possibly react with your next layer of paint.
As said above shoot a mist of black or a dark colour over it, block and wet 600/800 till there is no guide coat left the, dry it, tack it and shoot your top coat
I'm pretty happy with it so far, the third coat looks patchy but it was just after spraying in the picture.
Thats not the wing from my car, which is why i'm playing about really so i can practise and experiment.
This its current state lol, only me to blame for that though.
Noob question, What do you mean by "tack it"?
He means use a tack cloth which is as it sounds is a sticky disposable cloth that picks up any fine particles that that have been missed. Before tack cloth use panel wipe which is a spirit that takes off any contaminants which can be bought like wet wipes or in a can and used with a rag.
You can get these items from an automotive paint supplier or a good motor factor. Good job by the way.
Edited by MacColl
So a bit more progress, not sure what people will think
First coat of colour, pictures of it when wet so bare that in mind lol
Then I think this is the second coat but dry.
Bit annoyed cos you can't see in the picture but the can ran out and spat paint out on the second coat so i'm gonna do another quick rub down blast over quick.
I know i didn't do a guide coat but i'm only experimenting at the moment so be kind lol.
Let me know what you think, any more help much appreciated.
Cheers, George
remember, any orange peel can be rubbed out and polished! Just as long as youve got enough paint on jobs a good un!
Thing is, you can't really tell in the picture but its like a matt/satin finish lol
no rubbing and polishing matt stuff, as it comes from the gun is how it stays
yeah thats what i thought lol, where can i get aerosol cans of primer cheaper than haulfords cos i can't imagine their the cheapest.
you can get them from poundland and those sort of £1 stores etc, to be fair, some of its alright, I've had like 3-4 kinds from there, and only one was actually alright. the other was different from can to can, and nozzle constantly got blocked. if you wanna do a decent job, id get some decent primer. but yeah halfords is a rip off. try a local paint store or something? nice work so far btw :)
Cheap primer = shit finish or soft paint underneath, plus the chances are that they may react with one another and mess up top coat, which would mean taking it ALL off
Simoniz is the worst primer i've ever used.
fair play lol, won't be using that, but i'm also thinking with matt paint i won't need to primer the whole car, maybe just the bits that have been rubbed to bare metal???
Anything bare metal WILL need etch primer, then normal primer then topcoat, Also if your using rattlers then put them in a bucket or hot water for 10mins before you use them, it gets the contents warm and makes the paint flow better, also keep the can vertical if you can whilst spraying
Do i only need one coat of primer then? Where can i get it in cans that will be cheaper than haulfords but just as good quality?
Edited by drunkpunk91
