MASSIVE house clearout
All Mk1-3 Polos
3)Mk1/2/3 Polo Rear Wiper Motor – 861 865 713 C
4)Mk1/2/3 Polo Rear Wiper Arms x 2 – 172 955 409
5)Mk1/2/3 Polo Rear Strut Covers x 3
6)Mk1/2/3 4 Speed Anti Roll Bar Powdercoated Black unused but marked
Mk1 Polo
8)Mk1 Polo Late Seatbelt Retainers
9)Mk1 Polo Header Tank – 861 121 407
10)Mk1 Polo Facelift Chrome Trim Dash Grille Surround
12)Mk1 Polo Parcel Shelf Support Passenger Side
Mk2 Polo
14)Mk2 Polo 4-Speed Gearbox Mount
17)Mk2 Polo Coupe S Exhaust Flexi Section
18)Mk2 Polo Coupe S Metal Cambelt Cover
20)Mk2 Polo Coupe S Steering Wheel Horn Press
21)Mk2 Polo Seatbelt Retainers
22)Mk2 Polo Fan Cowling
23)Mk2 Polo Fuel Pump – Dated 2000
Mk3 Polo
24)Mk3 Polo Window Seals Rear – RH + LH
25)Mk3 Polo Amber Front Indicator Lenses – marked SIDLER 1115 + VW
26)Mk3 Polo Wiper Mechanism & Motor
27)Mk3 Polo Black Sunvisors
28)Mk3 Polo Front Quarterlights
29)Mk3 Polo GT Stub Axles
30)Mk3 Polo GT Drum Back-Plates – 220mm in diameter
31)Mk3 lower steering cowling cover 171 953 516B
32)Mk3 Polo Passenger Remote Adjustable Mirror
33)Mk3 Polo Front Wiper Mech & Motor – 251 955 119
35)Mk3 Polo Filler Neck Rubber
38)Mk3 Polo Petrol Flap – Silver
39)Mk3 Polo Bosch ECU 030 906 026 N
40)Mk3 Polo GT Airflow Meter 030 906 301
41)Mk3 Polo GT Steering Rack 862 419 105
43)Mk3 Polo GT Pulley 030 109 111 B
44)Mk3 Polo GT Alternator Pulley (Crank side)
45)Mk3 Polo GT Rad Cowling Cover
Mk4 Polo
48)Mk4 Polo 1.4 16v Power Steering Pump Pulley
49)Mk4 Polo 1.4 16v Power Steering Pump Pulley + Pulley
50)Mk4 Polo 1.4 16v Crankshaft Cambelt Sprocket
51)Mk4 Polo 1.4 16v - Plastic Dizzy Cover & Lead Tidy 036 103 565A
52)Mk4 Polo 1.4 16v Power Steering Pump Pulley
Mk5 Polo
59)Mk5 Polo GTI 1.6 16v Engine Wiring Harness
Lupo GTI
63)Lupo GTI 1.6 16v Hydraulic Clutch Release Cylinder 600 721 261A
64)Lupo GTI 1.6 16v Engine Wiring Harness
65)Lupo Gti Pedal Box + Drive By Wire Unit – 4A0 721 757 A
69)Lupo GTI Upper Gearbox Mount 6E0 199 111F
70)Lupo GTI Flywheel – 030 105 271 D
71)Lupo GTI OE Sachs Pressure Plate
72)Lupo GTI Clutch – 036 141 032 H
Mk1 Golf
77)Mk1 Golf GTI Warm Up Regulator 438 130 073
78)Mk1 Golf GTI Cam Pulley - 056 109 111A
79)Mk1 Golf GTI Lower Crank Alternator Pulley
84)Mk1 Golf GTI New Downpipe Gasket
87)Mk1 Golf GTI Oil Cooler Hoses
88)Mk1 Golf GTI Series 1 Contact Breaker Dizzy - Near New Condensor & Contact Breaker 049 905 205E
89)Mk1 Golf GTI Series 1 Parcel Shelf
90)Mk1 Golf GTI Complete Series 1 1600 Head / Cam / Water Housing / Inlet Manifold / Throttle Body
92)Mk1 Golf Bosch Starter motor 055 911 023L
94)Mk1 Golf New Tensioner Stud
95)Mk1 Golf New Linkage Rod Bush
96)Mk1 Golf Tintop 3Door Green Tint Glass Front Passenger/ Rear Drivers / Rear Windscreen
97)Mk1 Golf Tintop 3Door Clear Glass Rear Passenger
98)Mk1 Golf Coil & Coil Mounting Bracket
99)Mk1 Golf 8v GTI Oil Seals
104)Mk1 Golf Stub Axles – Brand New
107)Mk1 Golf K-Jet Throttle Body
108)Mk1 Golf Gear Linkage Piece (2 ball joints to fit both linkage rods)
109)Mk1 Golf GTI Series 1 Centre Console – 2 Guage
111)Mk1 Golf GTI Series 1 Speedometer Cable Complete with Driver and Gearbox cover plate
112)Mk1 Golf 10mm Laser Cut Exhaust Spacer Flange
113)Mk1 Golf Poly Steering Rack Mounts – New – Superpro SPF1932K
114)Mk1 Golf GTI Arch Trim – 171 813 817
Mk1 Golf GTI Arch Trim – Pattern
Mk2 Golf
115)Mk2 Golf 16v Throttle Body 027 133 070
116)Mk2 Golf Rear Pressure Regulator
Others
118)Coil used in Emerald Setup - 089 04B 00104 - Leads from top left, clockwise are 14,32,27,41
120)2.5" NOS Veglia Borletti 8 Bar Oil Pressure Guage
121)BMW Smaller, Lighter Power Steering Pump Pulley to fit Mk4 Polo 1.4 16v - 1715769
126)Slimline Ali Rad 12"H 1.75"D 20.5"L 23.5" between mounting lugs
127)Window Winders x 2 – 111 837 573 B
128)Window Winders x 1 – 191 837 579
129)Lazer Brake/Fog Light and loom
130)Metal Window Winder 443 837 581 D
131)Headlamp x 3 – 862 941 751 B
132)Parcel Shelf Holder 861 863 417 B
133)Universal 13 Row Oil Cooler – Push-On Fittings
134)Rear Wheel Cylinder – 654VG0271
135)CBR600 Lower Air Panel + Rubbers
136)CBR600 Full Airbox (Lower/Upper) with K&N Panel Filter – No Carb Trumpets
137)Delocked Door Handle
138)Weber Throttle Butterfly / Body – Cable Operated – B8WF9E71CB - 52CF2A 354U
139)**Was retro-fitted to a Lupo GTI Manifold, will fit Polo AFH/GTI manifolds with two gaskets.
141)Front Wiper Arm – 18 inch
142)Dizzy Cap – Beru VK106ES
143)Dizzy Cap – Beru VK307KM
144)Speedometer Cable x 2 – Spring Loaded to Clocks
145)Speedometer Cable x 1 – 861 956 801M
146)3mm Universal Spacer
147)HSS Motorsport Tailpipe attachement 'Bosuko' – 5542470-01
148)Lupo GTI? Steering Column
all pics here
http://s134.photobucket.com/albums/q104/wi...snowball/parts/
collection from central manchester or bolton, can deliver to derby/northampton and surrounding areas for some petrol money
email yousafn@gmail.com, text/phone 07950 675 910, or either reply on here, or drop me a pm
thanks
saf
Edited by grungeisdead
  • Replies 111
  • Views 5.8k
how much for the steering wheel ? posted
35 quid posted
loads more parts in this link
http://s134.photobucket.com/albums/q104/wi..._snowball/parts
will be listing what I've taken pictures off, as i have another 50 items to list, plus more at the unit that is packed and just needs to come to the house
see updated thread
prices for no1....i take it a chinese will also be delivered?
15 quid + postage
chinese? what you on about lad :lol:
i farking hate chinese food
number 91, price posted to my inbox along with the paypal address please.
Egg fried too.
i get the chinese joke now you tools haha
rich you have pm sir. still got la lupo box for you
No27 is it the Cam pulley? (sorry i can't see pics at the moment) If so is it a square or round tooth profile?
Edited by dekerf1996
yep cam pulley iirc its square willl check tonight
saf have you got a Afh 1.4 16valve timming cover & the little plastic piping to the back of the water pump knocking around ?
got the water pump pipe mate, no spare timing covers sorry!
Sweet p.m me a price & i could come pick it up when ever or when the mani`s are sorted
safe
kfc or burger king mate and its a deal.
pop round whenever, the mk1s back at my yard if you want a mooch.
bring the mini! MIIIIIIIIIIIIIIIIIIIINIIIIIIIIIIIIIIIIIIII!
Swa eeeeeeeeeeeet ! ye il bob round sometime soon I'm not driving the mini anymore man : / insurance is a joke for a 1380 engine at my age its on the driveway awaiting two new drive shafts & a lowering kit to be done this weekend my dad is blooming about in it everynow & then its going up for sale soon :-( need the room tho want to get another polo on the driveway
You have PM mate; x
have you managed to have a look yet??
no mate completely forgot, wont get a chance until sunday night now as I'm going back to my rents for the weekend!
sorry fella, drop me a pm sun-night and ill get on it!
btw there are pics in the above link and i tried to capture the teeth size
saf, you got any small backboxes, doesnt matter what there off as it will be bodged on anyway :thumbsup:
and how much did u want for the gt afm? think mines playing up, u jinxed it!
thanks pal.
Edited by mattpolo5491
hahaha call it 15 quid for the afm?
got a powerflow backbox that was from a mk1 golf driver, might be useful. just cut the pipe off after the backbox and rest of your system welded to it.
word :)
il see what the jobless money front is like after the week end, dunno about the back box now think it will have to wait, as the car just keep cutting out even when i set a high idle :( , i have a jetex backbox if you are interested. although they look a bit big for mk1/2 polos.
just hooked up a tempory side exist for now :badgrin:
will give u a halla after the weekend :)
Bloody hell Saf. How much stuff did you think you needed? :lol:
How much for 93 and 96 posted out to me me old china?
