1300 MH ENGINE WITH NEW HEADGASKET.
Allright guys, got a 1300mh as removed from a mk2 polo ranger was told when i bought it that it had a new headgasket (i expect if i look thru the reciepts from the car theres one there for it)
edit: looked thru reciepts for it and found it was replaced 26/6/08 and the last tax disc ran out 30/6/09 in between those two points it was taken off the road and unused due to a bent track control arm on the front sus...
Ran well when i drove it home and pulled like a train , very strong... iirc it was on about 80,000 but didnt smoke and started on the button...
ATM its in my mk1 but i can pull it out for sale..
its gonna be:
*the bare engine with dizzy, inlet manifold and exhaust manilfold, all pullys and everything still fitted,
so to run it you should just need a carb..... (see below)
£80 or offers?
i can supply extra bits like a nearly new pierburg and all other bits to make it run if you need for extra....
loads more for sale soon inc a 5 speed box
PLEASE P.M ME
Edited by retrowagen12345
  • Views 192
How much for evrything apart from gearbox pal? Drop me a text if u want 07871490280 cheers
