Rust, what to do when repairing?
I'm currently preparing my car for a respray and have come across a few bits of rust, which i have used my angle grinder/harsh sandpaper to remove.
Do i need to apply anything else to it before i filler/primer over it? eg the rust treatments you can get? or zinc primer etc?
Dale.
  • Replies 10
  • Views 1.9k
I've been doing mine and this is what I done: grinded, sanded, then put in hammerite rust treatment gel, then put on anti rust primer, sanded it down, then filler, more sanding lol fill in dimples etc then sanding then primer... It's not going to hurt the car by doing the extra few steps ....
Wire wheel in a grinder and come on kids throw some goggles on for your eyes safety, also even though its hot put a top on as the wires hurt when they hit bare chest (or bare girly chest :) )
wheel it all off till you have good metal, rust treatment, personally i use hammerite liquid stuff, goes a blue/black colour once its worked.
Quick shot of Anti rust or zinc rich primer then in goes a skim of filler to smooth the dimples
Sand your filler once its hard (bear in ind it sets up quick in the heat) start out 150 and work your way down to about 240
Etch primer on any bare metal
Shoot some normal primer over that and leave to dry for 12hrs, then wet sand that with 600 so its ready for paint, either shoot you paint or leave until you do your respray
Edited by mad_will
use rust killer and then use an etch primer then filler and primer
you need to use etch primer to help then filler and primer stick
Cheers for that, so i need to etch primer any bare metal? even if there was no rust there before hand?
yep etch will almost bite into the metal so that anything else on top of it sticks
Ah rite nice, why does filler say its best to aplly onto bare metal then? as this is what I've done in some places :/
Should i redo it with etch primer 1st?
Filler CAN go straight onto bare metal, but any other orimer or paint will need etch under it.
So etch primer under any other primer or paint
Filler straight onto metal
Alrite niceone, thanks for the advice mate. :thumbsup:
Just doing my spray job too so this has been handy!
awesome!! this forum is really helping me and answering tonnes of questions. I'm taking the wing off my polo tomorrow to get at some rust on the end of the sill (that the wing stops me at getting too) and also attempting to at least get the door ready for paint (there is an area on my door right at the front about 2inch diameter)
