6n2 steering wheel
does anyone know how the steering wheel comes out of a 6n2 gti? theres two holes in the back (maybe to pop the airbag cover off) but cant seem to get them undone are they torx or actual screws?
thanks for your help!
From what I can make out it sounds like allen bolts? Just unscrew them and the wheel should come off? Be careful with the airbag etc, though...
Its a pain to get a thin screw driver in those holes and pop a clip off. But thats it, the airbag will fall out and then you can go from there.
To pop the clip off, turn the wheel 90 degress left or right, then get the skinniest screwdriver in there and all the way at the bottom you should feel a bit of metal, the clips clipped to that. Fiddle around and you should get the airbag off. Propa annoying though so have fun :thumbsup:
if there the same as a 6n then disconnect the battery for AT LEAST 10mins before you touch anything, airbags in the face hurt :(
Undo the allen bolts in the two holes at the back and pull the airbag unti out, carefully put it somewhere it wont get kicked, dropped or knocked (you CANNOT throw them in your bin)
then Centre bolt undo, probably a 22mm/24mm socket, hold the steering wheel so you dont break your sterring lock, new wheel on and tighten up and job done
Took me hours, kind of have to push a spring towards the centre of the wheel
