flaring rear arches
if you flare your rear wheels archs they will stick out further that the back bumper. is there any way to get over it?
On what car?
Illguess at a mk4, if so then the only way is to pie cut the bumper and either heat and mould it out to follow the arch and then plastic weld the gaps
yeh mk4, any one got any pics off the the arches flared on a mk 4
as will said, you need to cut, heat up and bend the bumper to match the flare and then some plastic welding and filler
What about the rear arches on a MK3 polo?
