Mk2 Bready de-spoiler?
Any one removed the spoiler/plastic shit of the back? took it off and theres a shit load of holes for the grommets too sit in have people just fillered these out or what? any help apprietated :)
  • Replies 8
  • Views 1.5k
haven't took one off but if you do i will have it off you mate
idealy needs the holes welding up...or find a tailgate off a poverty one
seen one that had been welded filled and sprayed look very different but quite good
For all the effort you may as well get a ranger or fox tailgate and get it resprayed.
Cheers guys and yeah thats probs best option cba with welding, filler ect.. and i'll give you a pm if i get rid of it mate
I welded mine as above, cut perfect little discs of metal. Just make sure you get the welds ground down enough below the filler because I ended up having high spots of metal which can have a detrimental influence on the finish. Finding a plain tailgate is probably the way forward if you don't have a welding source.
macoll....read on a hotrodders forum , use a nail to plug the hole, upside down obviously then you have a handle to hole while u weld ...then gring it flush
thought it was a nice tip
^ That is a great tip, I'll log that one for the future. Can't beat old tricks of the trade.
