Question Question...
Anyone smoothered there side repeters off on a mk3 ? If soo what did you do/use i heard that the side panels dot come off on mk3s?
  • Views 756
Side panels dont come off? i think someones been telling you porkies...
Basically weld on a plate from behind, then skim over with filler, sand down, get it painted, simples
Although MOT time it may be a bit dodgy with no side repeaters.
I looked into this before and apparently (I dont know this to be 100% true, just what i got told)
that if you go to the rear of the car and step out 1 metre, you need to be able to see the front indicator flashing, or itll fail MOT
But that could be bullshit so try popping to a garage and asking them the regulations, or I'm sure youll find them online if you dont mind reading through loads of stuff
Oh and if your not too familiar with bodywork, dont weld all the way around the plate in one go, its only small but the continued heat could warp the panel,
tack it at each corner then build it up along the edges, giving it time to cool down just incase,
then obviously rust proof!
