Oil Leak from my 6n
Hey, I have a 1.0L 6n polo and I've been noticing that is has been leaking something onto the ground wherever it is parked.
I think it's coming from the front of the car, at the RIGHT hand side - Drivers side, that is.
I've just looked onto the road today and as it's been raining the stuff that's leaked out has that rainbow effect to it.
I've touched the leaking stuff and it has the consistency of oil 9and the smell as far as I know)
I pulled out the dipstick, cleaned it and put it back in, then out again and there is about 1cm of oil at the bottom of it and that's it.
I've also unscrewed the oil cap and there is no milkyness/gunge in there - it all looks normal.
Any ideas, what might be leaking - which things should I check? Help would REALLY be appreciated!
Edited by Spade
  • Replies 29
  • Views 9.6k
Have you checked the sump bolt is not leaking? Also check the seal around the sump, and check the sump for cracks. I would top up your oil a bit as well if I were you.
Thanks, I'm a total engine novice and have not yet received my Haynes manual - which bit is the sump? Also how far up the dipstick should the oil come?
It could be the gearbox side?
Selector seal or something similiar?
The gearbox is on the right hand side I think so unless it's leaking sideways along things I don't think it's that.
The gearbox is on the left hand side of the car.
It's on the passenger side.
Sump is at the very bottom of the engine.
When you take the dipstick out, wipe the old oil off and you should see a max and minimum mark.
Then put it back in and recheck it.
ah yeah, you're right, I've been thinking in my head of the car as I'm facing it! Crikey!
OK, just been out to the car, few observations and questions:
I'm pretty sure that I've found the whereabouts of the leak and I'm 99% sure that's it's oil. The leak seems to be coming from where the dipstick tube/pipe joins the engine block. I think I've read somewhere else that this happens - any further ideas/advice?
Also, on the dipstick, at the bottom, is the hatched area in the 'kink' the min and max markers?
http://www.clubpolo.co.uk/forum/index.php?...amp;hl=dipstick - would anyone agree that this could be the problem with mine?
Blocked Breather Pipe?
Although it doesn't seem to be coming up my dipstick pipe? It seems to be around the base of it.
Edited by Spade
Yeah the dipstick should be filled somewhere within the hatched area in the 'kink'.
Edit: Also, when adding oil, add it a bit at a time and let it settle for a while before adding more, otherwise you can overfill it without realising.
Edited by patchb
I defo need some more oil in there then!
and thanks for the advice on filling slowly. Any idea on oil type?
Edited by Spade
usually there's a litre between min (bottom of the kink) and max, (end of the hatched markings)
You should be able to replace that dipstick tube if it's cracked and leaking.
OK, found the culprit and have witnessed it leaking with nothing coming from above it. What is the blue thing in this picture and why is there oil leaking from where it joins to the engine?
hiya mate i know what it is since mine done the same thing it leaks from the cable part it is the oil presure switch/sensor you will need to replace it (make sure you get one of the same colour when you do)
jamie
jamie
Thought it might be that! Thanks for your help! Is it easy to replace? How is it done?
Oh yeah, and, where can I get this exact part from - can anyone give me a link?
Much appreciated!
Edited by Spade
My pressure sensor went as well, Your lucky that yours is leaking out slowly, all the oil disappeared straight out of my car, and I could hear the tappets within about 2 seconds lol :(
Is it a case of screw out, screw new one in? Might go to GSF now (when my wife gets back in the other car!!!) and get the part.
Edited by Spade
No problem :D
yeah its not to bad you will need to remove the air filter 4 long screws and a hose and then you will need a big socket think its somthing like 24mm becouse i didnt have one big enough
think thats it just check yours is defo blue though mine was green :D
jamie
Thanks for all the help! Really useful! Going to pick up the part now! Will also pick up some oil - what oil should i get?
no problem glad to be of assistance lol
erm i think i used 10w/40
but can be 15w/40 ,15w/50 or 20w/50
jamie
jamie
Opie Oils recommend 10/40 or 5/4o for mine
go for 10w 40 :D
jamie
Yeah that's what I just got! Gonna attempt to fix this before it rains!
