Service
Ok so i asked the VW garage how much for a service they quoted me north of £200!
I asked a local garage and they said £75 for sparks and oil filter change.
How hard is it to do it yourself?
Parts are well cheap but am i entering a world of pain?
Just had a new clutch and 5 speed box dropped in it, the water pump is new, cam belt is new, brakes are new so i want to fresh up the rest of it.
Holla
  • Replies 14
  • Views 1.8k
I always do my own servicing, saves me a fortune! £75 isn't bad for sparks and oil though. Get yourself a haynes manual, its a very valuable investment! Oil, oil filter and sparks isnt to hard or time consuming, should only take an afternoon for a complete beginner!
It isn't that hard mate aslong as you've got a good set of tools(Haynes so you know what your doing if you haven't done it before).
If you put your reg into ECP they even bring up the right parts for your car.
For £75 you should be able to get some quality service parts, it shouldn't cost that much though.
Definately do it yourself; nothing is very hard to do on a MK3. Even if you have to buy a set of tools the first time it will be cheaper than VW. I service all my own cars including the 4 year old Ibiza Cupra. I object to paying the £200+ that Seat want to service that one when all they really do is change the oil (£50 of the price is for the oil!!!!!). I also do a better job.
Yeah piece of piss to do a simple service
Heres what i change when doing a normal service..
Set of new spark plugs
Oil filter
Sump plug
Air filter
Oil
You'll need some basic ratchets and sockets, a spark plug socket and oil filter gripper thing if the filter doesnt have the hex shaped bit on the bottom (you can just stab a screwdriver into the side of the old filter though to lever it free if you cant loosen it by hand)
Start by taking the sump plug off (make sure youve got a bucket/bowl to catch the oil) that way, by time youve changed all the spark plugs and air filter, the oil should of all drained out
Then swap the oil filter, put the sump plug on and fill up with new oil - simples :thumbsup: :-)
Oh, and username = cool as fuckery 8-) :-D souls of mischief are top
Do it yourself mate, 200 quid is an absolute rip off. All you need is a spanner to undo the sump nut and a long reach socket to undo the spark plugs.
Take the car for a little run beforehand to warm the oil up a bit. This means you get it all out when you drain it cos it's thinner.
Prepare to get oil up your sleeve / all over your hand when you do your first oil change :lol:
First? i still get the warm arm sensation even now, after 9 years of oil changing :oops::lol:
Nothing much too add. Absuloute piece pissss :)
Same... :oops: lol!
It's useful to unscrew the sump plug but keep it pushed in as you do it, then when you know it's completely unscrewed you can quickly pull it away and minimize oil spillage all over yourself.
last time i got it all down my face,arm and near my armpit lmao..
Same... :oops: lol!
I change the oil on my cars every 4-6k (doing 30k+ a year it happens alot) and I still get covered in oil everytime I do it.
Just remember to wash your hands before your next wank!
If Calsberg made sex acts turned into slogans, they'd probably......
Oils awesome. Works like a handcream tbh. cures dry skin like nothing else :lol:
But yeh, I've always serviced mine myself. Get a haynes manual, tells you how to do everything in great detail :)
also service my own cars myself,have done since i was 18
its cheap and you know things "have" been done,plenty of rip off garages out there
