half way through de-wipering
heyy I'm half way through de-wipering my 6n ..
this is how far i got but the motor does not seem to want to pull through :( .. may just be me being slow but any ideass why this is ?
cheers
Edited by Chris121
  • Replies 9
  • Views 1.5k
Don't pull it you might dent your boot! W&d 40 etc and work it out gently!
oki dokeyy ill go try it now
nope didnt work ..
I had same problem! If wd40 don't shift it use some better penetrating oil and turn the wiper motor whilst gently but firmly pulling it if you can! Eventually it comes out! It's not been touched for years!
take the rubber/plastic bung off the stalk on the outside of the car and then try< if not give the end of it a tap into the car (dont hit the glass though)
Hit it mun!!!! what i did on mine!!! hit the metal bit thats sticking out
tap the outside stalk with a hammer. done.
nahh that little black plastic bung dont want to budge .. .. hmmm :?
got a soldering iron????? if so fire it up when it hot enough melt that sucker off! (get a flat blade driver aswell to pry it apart so it dont stick back together)
if not try heat a knife up on the kitchen hob (use a DRY cloth on the handle so you dont burn yourself) and use that!
