How To De Seise Coilovers
i have just purchached a set of coil overs and the ajustable rings where the C spanner goes are seised on and can not be moved, any ideas on how to loosen them?? i have tried WD40 and a leverage bar but just started sheering knotches off :cry:
any help world be gratefull as i dont want to saty at about 80mm i wanna go 120mm :) thanks alex
  • Views 1.2k
More WD40 :D just keep soaking it and let it settle in there.
Maybe give C spanners a knock with a hammer, Bit of a jolt might loosen the threads up
When mine had siezed, I have a clamp in my shed, just mounted one in there and went mad with the c spanner and a hammer. And loads of penetrative fluids.
ok here's a list of thing to do and I have used pretty much every one on mine! Lol
Loads of penetrating oil decent stuff not wd40/ freeze lock stuff from halfords works sometimes!
Clamp them up in a vice nice and sturdyily
Tap the adjusters all around to dislodge the rust
use a bar on the end of the c spanners
soak in diesel over night!
Get some of these locking clamp mole grips
these where the dogs danglies for me all I had to do was grind the points down but by bit they fit in the adjuster gaps perfectly (if there fks then u may need to chop/file the notch out fully) then whacked a bar on and off I went!
That dint quite cut it on a couple of ring so I gave it some very light blow torching (I put the torch on counted 2 moved it to the otherside, counted 2 then had a go with the clamps n bar if it moved I carried on man handling it! Only use enough heat to break the initial seizure!
plus gas, c-spanner and an exhaust section made mincemeat of siezed coilies i had been battling with for days
