Painting doors
I've had a search through the forums, and didnt really get a straight forward answer to what I'm wanting to do. I realise that you have to sand down the door, then prime it, sand that down, paint it then lacquer it, but there isnt really a mention of the specifics or any particular technique that you should be doing. We've already tried to paint a wing & bumper on a mate's 6n, and it didnt turn out a 'metallic' colour (i.e. wasnt really shiny), even after the lacquer. So to summarise, it would be great if someone just wrote up a simple text guide on what todo from scratch. I've basically got two doors, one silver and one green, and they need to be painted black. (C9Z, so black magic I believe) Many thanks :)
  • Views 1.2k
DO NOT use cans with metallic colours as it simply wont work, you need a decent gun and comp set up or you simply wont get the finish
cobblers. I've painted the whole lower side of a polo before in metallic paint and it came out fine for what it was ( a cheapo car done over a weekend, outside on the drive)
if you take your time a prep the panel well, its easilly possible to paint a door using rattle cans. Another key thing is to get the cans from a decent paint supplier and not some spotty halfords gimp. a compressor will make an easier job of it but tools are only as good as the person using them.
I appreciate the input, but it still doesn't solve the original question :lol:
what paint did you use last time? your method for painting is perfectly acceptable, so i can only assume you were using cheepo paint. ideally you want to spray in a warm place too.
once the panel is painted you want to leave it for a few weeks, then remove any imperfections using fine wet or dry paper (used wet) if your happy with the panel you can then go on to buffing it up so its shiney (rattle can paints do dry to a slightly dull finish especially if air dried (i.e. not oven baked))
heres a wing i did using rattle cans at work in a warm workshop (note the finish is still slightly flat)
heres the wing fitted
next i gave the fresh paint a cut back with some autosmart colour restorer
in this pic you can see the difference. the door was sprayed outside in the middle of winter at around 5 degrees C
i know the mk2 is non met. paint but the method will work just the same.
So no sanding needs to be done? Effectively speaking, all I need to do is grab one of the silver doors, spray some primer, let that dry, another coat of primer, let that dry, then first paint coat, let that dry, another coat, let that dry, another coat, let that dry, then lacquer, dry, lacquer, dry, lacquer? Where could I get some good quality paint? Was using halfords the first time :lol:
Use about 500 grade wet and dry on the 'silver' door. Also, be sure to degrease between coats with panel wipe if you want the paint to last. A paint supplier will provide the paint. Contact a local body shop for locations of a good local supplier. Also, if its available, get 2-pack in a can, as its a lot easier to get a decent finish. However, use a well ventilated area, and be sure to 'water' the area aroud to trap dust on the floor. Its expensive too, but worth it. Then cut back and polish when completely finished.
Search the net for more advice, there are som good how to's around.
