Fuel tank for a MK3
My fuel tank has got a massive dent in it and the gauge is not reading properly!
Been looking in scrap yards and they've quoted me about £60,
If anyone has one let me know!
Any help would be great,
Cheers.
  • Views 1k
You can buy a brand new one for around £60 mate...
Cheers.
i have got one it was off my mk2 but they are the same as the mk3 i changed it because i am not using carbs any more i have put a gt in mine. you can have it for 30 matey
Ah ok,
Cheers mate, will look at getting it fitted etc before committing.
I will most likely come and collect once i have the overflow pipe sorted :)
Ah ok,
yer mate no probs if you want it just give me a PM :-D
They aren't the same
Injection tanks are different to carb tanks ;)
You can use carb tanks on injection.
Carb tank has 2 metal pipes for supply and return (I think that's what they're known as?) all you do is get a small length of fuel hose and just connect them together with the hose and jubilee clips. Job done.
thats why i said i changed mine because i am now on carbs if he is running carbs then it will fit :-D
