what to do after painting ?
just paintedwith 2k base coat gambia red my mk2 is there something i need to do afterwards like some sort of mopping I'm quite happy with the finish just feels rough for some reason any help would be great
thank you
  • Replies 8
  • Views 1.5k
What paint did you use? celly/2 pack or waterbased? Has it got CC on it?
just paintedwith 2k
:roll:
2 pack i have used. dunno if thats any help or not but. i dunno what to do next :( the paint just feels rough on more or less the whole car :( dunno what to do next
cheers tom
Edited by TomMK2
Wet flat it with some 1500 and go over it with a polishing mop and some G10 finishing compound. Will get it nice and smooth and mega shiney, although you might want to leave it a week or two to get the paint nice and hard.
o right cheers i didnt know if to use g3 or g10 after wet flatted it :s
I have always used g10, purely because it says finishing compound on it lol. I have always used it and it has been fine and makes a nice glossy finish.
But if people say I'm wrong for using it, I'm not going to change it as I have loads of the stuff.
hi bud wet flat with 1500 and 2000 all ways use a block then use g3 comp with a gmop and lots water be carefull not to burn the paint or polish throw the paint then use a 3m machine glase and it will shine like glass?
If you're going to use a mop, use G3, its finer so should give a better finish. G10 is better for a hand finish (since its easier to work in than G3). Otherwise, flat back with 1500-2000, G10 it and the you MUST polish after. G10 leaves microscopic dimples which will fill up with dirt if not polished. Plush, you'll get a better shine from it
Edited by prankstar2003
