clutch?
rightio guys dont know if you can help me???
thrush bearing has gone on the valver,so I'm going to change the whole clutch system....
loooking on gsf and i cant tell which one i will need...
there is two kits.....
190mm.............200mm which one goes to the valver.......
or does anyone know of any company's that do decent clutches???
cheers guys and gals nick
  • Views 661
"LUK" are the OEM ones (yellow nad white box) that vw get them from so would recommend them, never game me any problems.
your engine number should help guide which clutch it is or pop into your nearest VW thye can tell you.
ETKA usually lists is as engines up to number XXX =________ and after XXY =______ its not bullet proof if your cars a change over year model but its better than a stab in the dark.
