Polo 6n VR6
The car
P-reg (97) VW Polo 6n 3 door. Car has covered approx 80k miles prior to conversion.
It was originally a 1.4 16v
Currently has 10 months MOT
The Conversion
The conversion has been carried out over the last few months and is now finished and on the road, its real maiden voyage was to Bristol Volksfest last weekend where we expected a few teething problems (as you must expect when doing an engine conversion). The only fault which came up on Vagcom was a Hall sensor fault, this will be replaced this week. Other than that the car runs exactly as it should and is smooth to drive. If driven sensibly it is a job to tell the car has had a conversion, but put your foot down and expect the power of a VR6 but in a light weight Polo :D
I'm expecting most people to assume it handles like poop, but i was amazingly suprised at how well it does handle, the VR engine up front has made very little difference to the handling, it feels very tight and precise dispite what the keyboard warrors may say about VR conversions in small cars. If the car is converted well and uses a good setup it WILL handle nicely.
The Engine
The AAA 2.8 12v Mk3 Golf engine is sat on a custom made front cross member, and custom engine / gearbox mounts. The lower arms have been seam welded to provide extra strength, and are polybushed throughout.
The Engine still use exactly the same setup it would in a standard VR6 by using the orignal Carbon filters, CAT, etc so runs like it should.
The car is sat on Coilovers (cant remember which make) and use Drilled 280mm G60 Disks and Calipers with green stuff pads.
The Timing chains, Tensioners and guides have all been replaced with brand new ones and the engine sounds so sweet.
Other new parts include Water pump, clutch, clutch master cylinder, headgasket and bolts, thermostat, inner CV joints, belt tensioner, radiator, 540amp battery, powdercoated Inlet maniolds and cam cover.
I'm sure there is loads missing on here so i will add them if and when i remember.
The car has to be seen to really appreciate the work involved in the conversion, and unfortunately the pics dont do it justice as my camera skills are shocking.
Car is located near Weston Super mare.
£3000 which is a ruddy bargain considering the work done to build this car.
More pics to come....
PM me for more details.
  • Replies 23
  • Views 2.6k
hi mate very interested in car can you leave a contact number also has engine size been changed on log book will it still pass mot on emmisions and stuff my number is 07961 539047 if you get chance thanks chris
you have a PM buddy. :D
Pretty much same question as above mate, general questions about legalites. Such as the V5 been changed? Anythign special for MOT if you know what i mean ;)?
Any other issues whatsoever?
cheers, Matt
More pics here: Clicky!
Yep, thats the car. :D
Cheers mate.
cheers, Matt
you have PM. :-D
Has this got back brake disc conversion or still on drums.
Drums
interested in a px with a 6n valver? is it decared as a vr?
no P/X's sorry
Still up for grabs. :)
Cant believe this hasnt sold already considering the price and what you get for your money!! :retard:
BUMP
Still here... will listen to offers.
that is epic! if i had the money i soooo would, what is it registered as? free bump
Still registered as a 1.4 16v as its up to the new owner (when it sells) if they want to change it to VR or not.
Just to add that the car is not being driven anywhere, its sat in a workshop waiting for somebody to come and give her the love she needs. :D
I want it sooooo bad but gota sell my leon first :( I'm after a weekend toy! Free bump
Hurry up and get shot of that leon then. :-D
Now on Ebay
Re-advertised on ebay.
want to swap it 4 my 16 turbo prodject??
No swaps or P/X's please as need the money to fund equipment / tools for the buisness, but thanks anyway.
I forgot to add the Ebay link so here it is.... :oops:
http://cgi.ebay.co.uk/1997-VOLKSWAGEN-POLO...309053481406928
SOLD
