reactive paint..
hey,
I was painting my mates mirrors off his punto the other day (why i dont know)
anyway,
they were plastic mirrors, already colour coded, and he wanted them white.
so i took them off, flatted them back so was all smooth etc, cleaned them with pannel wipe etc.
then gave them a few coats of plastic primer (allowed to dry etc)
then sprayed them white, let it dry, gave them another coat of white, looked ok, came back a few hours later to see how they were drying, and the paint had like bubbled, like it had nitromorse poured on the or something.
i had a look what it was, and the paint literally peeled off back to the bare plastic, its like id sprayed them with paint stripped instead of paint.
anyway, i want to do my mirrors, and i dont want the same to happen, could anyone suggest why it would have reacted in this way?
  • Views 907
Sounds like when you went over them with panel wipe dude that you hadnt allowed them to dry before spraying them.
This has happened to me before, in my case its cause it was a rather humid day and the moisture in the air had devloped a small film coating my mirrors, went through the stages as you listed above, everything was dandy until afew hours later just came right back off, as said it was because of this small film of moisture that had developed before i put the primer on so just lifted it all right back off
mm but i panelwiped them and dried them off, and was in a heated environment etc. i dont mind his fuckin up cause not my car haha but i dont want mine to mess up lol.
sound like your paint reac with the primer mate /just key the paint up and panelwipe it then spray it mate you only need plastic primer when you got bare plastic
