085 gearbox rebuild
I'm in the middle of an 085 gearbox stripdown and rebuild.
I have the box split, but I cant get the inpuyt and output shafts out of the casing because the shif mechanism is in the way.
I don't know how to remove it, The shaft that the mechanism is mounted to looks like it is threaded or pressed into the casing, there is a female m7 thread in the end of the shaft visible from the outside of the casing.
is there a special extraction tool, or will a slide hammer work to remove it, or do i need to lock a nut and bolt against is and unscrew it.
any advice would be much appreciated.
cheers
  • Views 1.2k
it's just pressed in, screw a screw into it and use a slide hammer
thanks again!
