cutting my springs
MOT is not for aleast ten months id av proper springs by then I'm hoping this for mean while and a lil play around to experiment wid the car for looks ,,this myt have to be done soon as i m feed up wid sky hi car huge gaps between arches and wheels jus wont go ott
  • Replies 105
  • Views 12k
But for ten months you'll drive around in a car that isn't roadworthy and wouldn't be insured? Good luck.
I've read that its not actually illegal if u tack the top of the spring to the cup. its only illegal because the spring drops out when the car is jacked up
I can't get over people saying that cutting springs is a good thing?
Surely as an MOT fail it renders your car illegal to drive on the roads?
Stretching tyres, having sticky out wheels, removing side repeators to name just a few, can be MOT fails, but people in the VW scene generally seem to suck the cocks of the people who do it
As has already been said, dont be a moron whith the grinder and things will be cool. I ran a car on chopped springs (propper lowering kit to start with, so better dampers) for about a year, and I'm still alive and I'm pretty sure no children were harmed either
I thought that, Torsion bar matey....
The Saxo that is....
Edited by slo-po
it's only an mot fail if the spring sits loose in the cups when the car is jacked up and you have to take a good couple of coil's off normally before this happens. also there are other ways around this i've heard of people cable tying the springs to the cups and my mate welded his to the cups.
his car passed an mot like that, i've also heard of people using cable ties and to hold them in place and a beetle i had some one had used jubilee clips.
But surely the heat from a grinder/saw is going to warp them somehow? And they it won't be a good job -- surely just working a few hours overtime and getting coilies would be better and safer?
Tbh the lad asked for advice on how to do it, not if he should or shouldnt, he wants to do it so why cant he? its his car and his decision end of.
cant work over tym with no job mate! :s
springs but to cut from the top or the bottom ?
I've always done from the top. its easy once you start
whats the difference between lowering springs and chopped ones anyway? my golfs on lowered springs (standard shox) the ride is shite but stance is shit-hot and when i jack the car up they hang and they sailed through an MOT!
hmmmmmm.
Just dont be stupid and chop too much off- you'll be fine!
Yeah top, the bottom have a smaller diameter to sit in cups so I think you can only chop the tops. Good luck.
Lowering springs have passed strict testing to be allowed on the road?
mate plz stop crying
just wondering is u cut the spring the ride gets harder..... right?
bouncier
Someone needs to play "devil's advocate" -- especially when it regards driving around in an unsafe/illegal manner.
I'm no jobsworth but this whole thing smacks of unsafe.
you sound like the police
And you sound like? :?
i sound like its his choice and up to him
I've done it to 3 of my cars previosly and never had a problem so jus chill
if you use a proper cutting disk on an angle grinder you'll be through it in a couple of seconds, i can't see the heat from that being enough to misshape a spring mate. even with the weld it's just a few blobs at the top and bottom, there's no way that's going to change the integrity of the metal in a spring in a way that's going to make it weaker.
agreed mateys done nuffin but moan my car my choice dont want to sound funny but i asked for advice not for a lecture,, does this make the handling worse or same as standerd
makes it better :D
and they dnt have to be welded do they to the top tht is?
everyone that saying do it I'm sure youd be advising differently if for instance he went smashing into your car and wasnt covered. because theres no way in hell that an insurance company would let you get away with that and then your left out of pocket. but by all means let him do it just dont cry when it happens... I'm with rosh on this one
