cutting my springs
and they dnt have to be welded do they to the top tht is?
not if they are tight in the cups, but i've driven car's were the springs are loose when you jack it up and they never caused me any hassle. some of these were proper lowering springs aswel, infact just remembered i had a mk2 golf that was lowered about 80mm on shocks and springs, the springs were loose in the cups when jacked up and that still passed it's mot.
  • Replies 105
  • Views 12k
everyone that saying do it I'm sure youd be advising differently if for instance he went smashing into your car and wasnt covered. because theres no way in hell that an insurance company would let you get away with that and then your left out of pocket. but by all means let him do it just dont cry when it happens... I'm with rosh on this one
in what way are chopped springs going to make him crash? have you ever driven a car with chopped spring's to even comment on how a car would be more likely to crash with them fitted?
My old coupe van ran on chopped springs, fronts were fine for mot, however the rears were far too short, had to be swapped for standard springs to pass. the ride wasnt too bad, but certainly not like a proper lowering kit.
He didn't say "more likely to crash" he said they wouldn't be covered IF a crash occurred.
he said 'by all means let him do it just dont cry when it happens'. saying 'when' means that he thinks it will happen
NEVER! repeat NEVER! chop springs.
lad round here chopped the springs on his civic, next day went out for drive, didn't expect to
bounce as much and smashed into a curb, destroying most of the passenger side suspension etc.
Seriously mate chopped springs ruin the ride (in examples I've both seen and been a passenger in).
He would of still crashed with normal lowering springs, going off that statement - "didnt expect to bounce as much" :lol:
i choped my lowering springs and i love lamp ! <3 lamp :lol:
To be honest mate he is a bit of a tit!
Chopped springs and chopped springs are two different things.
I said 1.5 coils off the front earlier for a reason - that much wont have a detrimental effect. It'll still pass an Mot because the springs will still sit in the cups due to the margin on preload. And it wont bounce about anywhere,the dampers will still be able to control them.
All this scare mongering about crashing etc is probably not far off only if you go chopping the springs in half. Use some common sense and remove only within the preload margin and its absolutely safe - and legal.
Btw,not all springs can be chopped. You cant chop a coil if it is concentric,only where the next coil is the same size. I know that on all pre-'02 Polos,that's the bottom of the front spring and either end of the rear. Not so sure of newer ones,may be the same,never worked on one.
seems taht every 1 that has chopped there springs are saying go for it and the people that aint got a clue are bitching about it !
mate do it and get sum pics up plz :D
I think mikey has the right idea, you can chop, but only to a point. So take advice from people who know their stuff. In the end its your choice, just be sensible about it.
Regardless of anythin else, if you take too much off, the ride will be soft, and the shocks are more likely to bottom out, decreasing the life time. Also makes for a bit of a shitty ride.
Best advice I reckon!
I wasnt trying to scare him I was just saying that the moron I know who did it must have cut them far too short and it destroyed the handling.
bait ride!! just dont slam it haha
Correct. I lost the top coil on my 6n2 and the spring basically floated around free in the cup when you went over a bump.
Ride wasn't affected from what i felt, but i really don't think it's a good idea.
It's his car, and, if he crashes, he has to pay out. Fuck knows how though - he has no job.
tbh i chopped my springs took a coil out but em bak on drove it but soon regreted it it was bouncy as fook and the steering felt mega wooly but it up to u at the end of the day
if you chop springs then your ride is going to be shit and stupid.
if it was safe to chop springs then they wouldnt make LOWERING SPRINGS!!!!!! they would just tell you were to cut using an illistration guide.
my mate choped the springs on his bmw, mot came= leaking shock= mot fail =EPIC FAIL
if you want to chop your springs then do it, you might have the money for some new shocks by the time your mot comes ;)
EPIC FAIL
Leaking shock would happen if lowering springs were fitted to standard shocks anyway.
The way springs are made doesn't naturally lend them to being butchered with an angle grinder.
Trust me, I butcher a lot of stuff with angle grinders.
if you dont lop too much off so the spring doesnt fall out and you put it back in the holders properly the mot centre will never know, having said that at work we have a g-plate merc s class thats about 4 inches off the ground with some silly camber on the back, and we took it for a mot 5 mins after we diid the springs and it passed first time
25902_108622842505752_108392859195417_10
Edited by ben_456
That's pretty fuckin cool.
I got a couple coils out the front, shoot me! :lol:
please don't talk shit, chopping a coil off a spring stiffens the ride, it doesn't make it bouncy (the only way this could happen is if your shocks were fucked). this is what i have found with the few times i have been gay enough to only do one coil and this is what practical performance mag found when they did a write up about it too. the ride is going to be no worse than just lowering springs put on old shocks.
and as a company that makes lowering springs how good would that be for business? :lol:
the story would of been exactly the same had he fitted the same size lowering springs on those shocks, so what's your point?
if he only takes a sensible amount off the spring then why would he need new shocks for an mot?
