car spray help
hey. i got a quote for a spray on just the exterior in the same colour (or any standard colour i want )
and if i prep it myself its 400 quid, i went to 2 places and it was both the same really, is that a good price and what needs to come off if i prep it myself?
the windows? the seals? the grills? everything that i dont want spraying?
no offence, but if they give you (the untrained unsure what he's doing monkey" the option to prep it yourself, they're not taking much pride in their job and you probably shouldn't take them up on it.
Find a detailing company, often it works just as well as a respray.
yes thats cheap if he sraying the whole car but if you doing in the prep and your not happy whith finish it your prob to spray a car is 75% prep. if the prep is shit the car will look crap.
the widows are bonded in maskup
are you geting it sprayed inside the door shuts if so you find out hard is thers alot bits that hav to be taken of ?
I'm very suprised they're prepared to take on that kind of a job, as if theres any issues with the paint, I certainly wouldn't want to guarantee the work myself knowing that I hadn't done the prep-work.
Working in a bodyshop, and having done a few bits of painting myself, including a full respray on a friends van, the end result is only as good as the prep that goes into it. You need to scotch down all the areas to be painted, mask out what can't be removed, and remove anything covering panels, such as side repeators or badges, etc. If the area isn't keyed well enough though, expect paint to peel
That sounds simple enough, but then if theres any rust, etc, you'll have to clean that up, smooth the affected area over with a skim of filler, prime the repaired area and blend into existing paintwork. Even then theres no guarantee fresh paint will keep the rust at bay.
I'd also want to know what they were doing for the £400. Whether they were literally just painting it, or painting, de-nibbing and polishing?
Hope that helps.
K.
