polo 6n pedal box's!
Hi, recently had a problem with my 6n it has gone through 2 clutch cables in the last 4 months, i know i fitted them correctly so thought somthing is wrong first time everything was spot on so thoght it was just wear and tear this time not so lucky looked abit more closely and saw that my pedal box had quite a large crack down it, i had feared this the first time as its a common fault on 6ns, well i started on monday stripped it all out which involved removing the steering column and i removed my dash pod as well for visibility, got the pedal box ordered on tuesday from vw cost £40 i thought not so bad, checked the parts agaist each other turns out they were slighty different, so phoned vw and said they sent the wrong part, turns out it was the right part but moddified and i would need to buy £140 worth of pedal moddifications to make it work, well i sent the box right back and resorted to welding the old one back up as i cant afford that kind of money!!! it should work with the amount of weld i put on it lol, I was interested to find out how many other people on here have had the same problem with there pedal boxs?? Cheers Dan.
  • Views 1.6k
Apparently the 6Ns are well know for the pedal boxes breaking! Not sure if it is or ever was a warranty issue with Vdub.
I had the pedal box go on my old lupo, changed it my self and now I'm guessing you have as much hate as me for them little bastard sheer bolts as me, i just orderd a new pedal box and brake pedal, it cost me around £45 and it fitted in no problem, and nothing was ever said about modifying pedals or a modified pedal box being available.
And IIRC, there was a call back on the polo 6ns (depending on the chassis breakpoint), how ever the lupo was never recalled but VW would replace them for free on goodwill (when they felt like it).
