1998/1999 Polo one side brake lights not working?
Hey Peeps,
I wondered if any of you peeps could help me here as I'm in dire straights, out of the blue the other day the normal night brake light and the brake light that comes on when you press the pedal stopped working on the passanger side of the car ONLY. The reverse light and the indicator on that side are fine and i have checked both of the bulbs and the fuses and they are all fine to. All lights including the brake lights are fine on the drivers side.
Can anyone shed some light into whats going on and what i need to do to get it working again?
Thanks in advanced and appreciate your help!
Edited by Bhavick
  • Views 1.5k
Hey Peeps,
Any help with this issue please?
could be dodgey connections ? that what was up with mine.
if not check to see if it has a good earth connection.
Get some one to put their food on the brake and put in an known working bulb and wiggle it a bit. It could be corrosion on the bulb holder. or if you have one get a multi meter on it and see if you have power coming to it.
