1983 Mk1 golf Black 3door tintop
Ok it kills me to do this but i simply cant afford to run/spend on the car
1983 Black Mk1 golf C Tintop
127,000 miles on shell 86,000 on new engine
MOT untill 29/06/2010
Tax till AUG 2010
1.3 Mk2 Polo Coupe S engine
5 Speed gearbox
GTI rear Bench
JVC Headunit - wiring implace for door speakers
False floor with space for a 12" sub and amp
Brand new tyre on spare wheel
Good Tyres on Steelies
New Orange front Indis
New drivers Headlight
New drivers Rear Light cluster
New CL splitter
Been checked over by a VW mechanic everythings sound, if not mentioned below
New dizzy/dizzy cap
New rotar arm
New Leads
New Plugs
Mk2 GTI coil
Mk1 GTI ignition Amp
Badpoints
Cambelt on new engine is slightly slack could do with changing
Front seats are quite tatty
Needs Front Screen wash lines
Winscreen scratched (new one will be supplied in sale)
Passengers high beam bulb has gone
Boot Keyed
Tatty but for a 27year old car not bad at all
Few bits of wiring left to do from conversion
Brake Master Cylinder gone - have a spare that needs replacing
Included in the sale will be;
The old 1.1 engine and box, i suspect the piston rings have gone on this but I'm not 100%
and MINT 4speed box
NEW fuel filler neck
Loads of other spares
Price - £900 ONO or swaps for a Polo 6N 1.0 or 1.4 8V
Collection from Northwales - Rhyl - If after 29th will need to be trailered
Pictures
Edited by Luke_mk3
Ok, to add to the add
The wiring issues are
The temp Sender, needs a new plug being made and then tapped for the sender unit from the golf engine to go in, to match the wiring...
Manifold gasket is cracked, this is blowing cutting the engine out on idle when warmed up!
Ok gave it a clean and took pictures of the ONLY bits of bodywork, and the ONLY rust spot, which the previous owner didnt get called up on the last MOT
(Steel wheels and 1 spare - 1 steel is sat on the car at the minute) IMG00060-20100620-1634.jpg
Thanks Luke
alright dude, fancy a swap, a mk3 vw polo genesis, its in the cars for sale section under mk3 vee dub polo gensis. would give you the link but I'm on my mobile haha :)
pm me if your interested
cheers man
craig
How much now without MOT?
This still for sale mate?
Think it went, swear I've seen a thread by the new owner elsewhere.
yeah went to me (under gfs user). sold
