new here, mk3 advice
my first post on here but i have been looking through a few project car posts and have allot of ideas for mine, need to sort out a few bits first though...
what i have done so far is stripped the seats and cleaned the whole car out (apart fom engine bay) and gave the rear view mirror some jewellery.
there is some rust around the car i intend to fix and paint myself.
would the rust around the petrol cap be better welded or just done with filler?
the rust on the door between the glass is right through does this mean i will need a new door and also are they easy to get cheap along with a front quatre panel?
i would also like to know if its a big job to replace the dash with one with a rev counter?
any help at all would be much appreciated and I'm on the look out for black door cards and corrado seats for it so if anyone wants the old seats and cards let me know. thanks alot
  • Views 733
theres a topic in the FAQ section about replacing the clocks for one with a rev counter. i done mine and its easy. took barely 20 minutes.
Welding around the petrol tank seems a no-go...
Some pikeys on here might say go for it :p
Best of luck.
Someone else probably has a better idea about the wiring for the rev counter, but the actual dash bit just comes out as one piece and the new one slots in. You use a set of stereo removal wire things in the slots on either side and it slides out. You will probably need to take the steering wheel off to do it (remember to mark steering wheel position with tip ex or something so it goes back on in the same place on the splines).
yeah sorry if this is posted in wrong place or anything, i will catch on quick enough lol. thanks, i will check that FAQ topic to see what i can swap it with. does anyone know about the door if it needs replaced?
