removing 6n rear glass
Hi all, I have a 1999 3dr 6n and I want to take the rear glass out, to be honest i'm a bit stumped as to how to approach it, i've taken off the surrounding trim and have good access to the bonding putty but it's hard as nails! I bought a glass removal tool, though I can't even get the blade from this into the putty, not even a stanley blade will get into it so what am I doing wrong? I'm stripping the car to be resprayed and I do need this window out because there's rust underneath it that needs sorting... I've thought of applying some heat and will give this a go this afternoon, but in the meantime any advice would be swell! Cheers
  • Views 615
window guys took mine out with one of the long snap off knifes you can get as it was a bit longer than a normal stanley blade. I also know a bodyshop fella who has a tool that oscillates very quickly, then you can add an attachment for cutting, it goes through it like a hot knife through butter!!
I did try using a longer knife on a multitool which worked better, looks to me as though the window's been taken out before though and rebonded back in with super-strong adhesive putty as it looks too messy to be a VW job, the other side came out a treat, I managed to shatter this side though :(, it'll probably be easier to replace it anyway
