R click problem
story cut short - the r click unlocks the car as it should no problem ther.. but it does not seem to lock the car! all the indicators etc etc come on when i press the lock button on the fob... but the car does not lock! :(
sorry if this is a repost...
any help really appreciated! =)
is it a plug and play kit or did you have to chop wires? check the connections if you had to chop the wires
yehhh it was plug and play.. :?
i had this problem and it was earthing. I cant remeber which wires it was but is on the wiring diagram (well on one but read all of the instructions) I had to use the little clip thingys to earth some wires. i think it was the 2 that actually take the signal to the actuaters to lock.
hope this helps
hope this helps
greeeatt!! thanks for that mate.. that was exactly what was wrong... it was a green wire! :-D
