mk2 with gt clocks
just wanting to no id i put the gt clocks in my mk2 will i have to change the inner loom or can i just plug them straight in? thanks matt
  • Views 656
the plugs are different dude but all the wires are the same colour so you just have to cut the mk2 plug off your loom and wire in the mk3 one but like i said the colours are all the same, i did it to mine.
i'd put the mk3 dash ion aswell if i were you, only issues i had were the two mounting lugs on the side of the dash to A-pillar need to be lowered and you need to trin the mk3 steering coloum cover slightly to allow the mk2 stalks to move freely but apart from that it took me 4 hours to do the full swap, even the rest of the switches have the same wiring colours so as with the clocks its just a case of swapping the pulys from mk2 ones to mk3 ones....
the only one i never dide was the light switch which i kept as a mk2 one because i'm not brillient with electrics and a few wires were different and i didn't trust myself trying to understand the haynes manual wiring diagram lol
