Petrol fumes coming inside polo?
theres no obvious leaks under the car, its only filled with 10£ at the pump each time so its not full , theres a constant spell of petrol which does get worse sometimes . does anybody know whats causing it?
  • Views 2.1k
The filler necks on the tank on the Mk3 Polo are bad for rust and rotting through mate...
Just replaced one that had rotted right at the bend where it goes into the fuel tank...
Failing that you may have had a breather pipe come off in the engine bay somewhere...
Edited by buster.g40
the tank was replaced 4 years ago i dont think it is that it looks ok.
where are the breather pipes I'm not familar with these?
I've got the same problem mate, check the exhaust for holes as this i think was my problem which i have fixed today.
The breather pipes however are pretty bad on these cars as well!
breather pipes go, main one runs from the acess panel under the seat, across the tank and then insed the drivers quarter behind the doorcard and onto the neck, worth checking its not rotten or perished, small breather looped behind the same doorcard wrth checking for leaks or smell, other than that try anew tank on it
Do you carry spare fuel in a can in the boot? With the recent heat the contents expand and push vapour past the seal.
id check the simple things 1st. had it on many a golf where the fuel pipe running into the engine bay has come a bit loose at the end :-)
i took up the access panel under the back seat i found today lol. and the big hose wasnt fixed on to go and petrol was leaking . plus a smaller 1 had shook its grip off . fixed it up with a screw grip thing. hopefully sorts the smell
