removing boot from mk3
do i have to remove the headlining to get the boot off?
i see some bolts but cant figure out how to get to them...
  • Views 845
nope the headlining can stay where it is. you need a small spanner or small ratchet to get at the bolts. it also helps to have a couple of mates to hold the tailgate, whilst you undo the bolts (you undo it with the boot open)
From what I can recall on my mk3 square it was 3x10mm bolts then you just need to remove the boot struts which I think was 2x10mm bolts again. Disconnect the electrics and jobs a goodun.
thanks!
the bolts dont look like regular bolts, kinda like the oppasite of a torx :s
