buying my first mk2 tonight- what to look for!
Hi guys
So I'm going to pick this little beauty up tonight, http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...RK%3AMEWAX%3AIT
What would you suggest looking for when I go to inspect it, what are the problem areas, rust prone parts etc.
Know nothing really about mk2s, currently own a toyota celica supra '86, used to have an '83 mk1 fiesta so know a bit about old cars.
Any helpful tips? I don't want to buy a rotbox!
  • Replies 11
  • Views 1.7k
The main place is the bottom of the battery tray, you can check it if you get on your back and look directly above the pedals up under the dash.
For £122 you can't go wrong really. Its nearly worth that in scrap if it goes tits up!
I'm giving him 350 for it. I have put a deposit down so don't go outbidding me please :)
Ah I see, what wheels come with it?
Mahle turbo bottle tops. They came as an optional extra on the BMW 2002. Apparently quite rare. But he would say that :)
So the basics, drive it and see how it feels, tyres, brakes check for wobbles. Rust, mainly under the battery tray but worth rolling around underneath with a torch. All electrics should be tested I guess. Engine wise, it should start ok without choke from cold in this heat, yeah? check coolant to see if it smells weird and check oil condition in filler cap yeah? Have I missed anything important?
Thing is you've put a deposit down without seeing it. Surely if something is wrong with the car now you would have to buy it or lose your deposit?
But yeah, all the usual things to check for. Ask him how much oil it uses/how often does he have to top up water etc
i would say you'd be hard pressed to find a model without a rusty battery tray so i wouldn't worry too much about it. plus its easily fixable.
Battery tray is solid! shes a winner!
Just a few jobs to do, bleed brakes, sort out the fuel smell when the car is running (only noticed it when driving though so far, grrr) replace the steering wheel horn push (its missing, anyone got one?) change the shit chrome bullet mirrors for standard ones, (anyone wanna swap or PX!!) and the exhaust rattles againts the body when you first engage each gear. (i don't think its bad enough to be engine mounts failure, I reckon I just need to strap it on a bit better than he did.) Oh, and rip out the shit mdf box he made in the back to mount a massive sub. Won't get my BMX in there otherwise...!
On another note, the bready is massive! I was expecting a tight fit (i'm 6' 3) but loadsa room!
Have fun with arch rub lol.
No rub at all in fact!
The back wheels are hidden under the arch- but they don't rub at all. Had it on two wheels earlier on a tight corner/slop junction (if that makes sense) because the suspension is so stiff!
Good call on the bullet mirror things!
