Window winder removal!?!?!
Just checking that it will be a clip behind the window winder u have to try unclip to remove the window winder?
Has been on other cars I've owned but doorcard is so tight to it and i cant seem to see or feel a clip!?!?
  • Views 2k
If you mean the handle, you pop the cover off the handle which reveals a screw to take the handle off. To take the door card off you need to take the window handle off, door handle (mirror adjuster knob just pulls off if there is one), door opener surround, unscrew two screws on the end where the door shuts, then there's various clips which tend to break off! The top of the door card wedges into metal grip things underneath the window seal so pull/lever the top out.
Hope this helps!
Yes cheers - i mean the window winder handle to wind the window up and down. I got all rest off then cudnt figure how to get that off. Ill have another go and look for a screw then
