Cant get my bonnet up :(
Hey all, went to change my battery on me 6n yesterday and pulled the bonnet lever and hey presto nothing...... theres feels to be resistance on the lever but the bonnet aint popping up...
any ideas how i can get the damn thing open??
  • Replies 11
  • Views 1.4k
get someone to pull the release then you pull the bonnet up could be the cable is to slack and needs replacing
Problems getting it up?
Have you tried....
Viagra?
Hahaha sorry...ill leave now :(
if you can manage to get the grill off without breaking the clips.......
i think theres a way you can do it from under there?
not much help to opening the bonnet, but always push the bonnet release handle back to it original position after pulling it, i've had mine stick because of not pushing it back.
Lean down on the bonnet, get someone to pull te cable, then lift it up.
Probably just the catch needing some oil.
Knight - I came on to say the exact same unhelpful thing :(
tried push pulling jumping on the bonnet b ut to no avail.... tried pushinh lever back etc and still no joy.. looks like i may have to try and remove the grill.........
Bit of bonnet viagra ;) um cable may have come off, see if you can get in the grill (may need lube) and get it that way, if not its smashy smashy grill time
Have you tried....
Viagra?
And i was going to say the same unhelpful thing x4
not sure on your car but on my mk2 I put the car onto ramps and there was enough room to lay on my back and reach up through the engine bay to the latch.
try pulling on the actual cable not the lever might give you that extra pop or big screw driver ? worth a go before you fook your grill
