Mk4 Polo 16v - Disabling Passenger Airbag
Hey All,
Gonna have to start takin the nipper to nursery soon and dont particularly fancy breaking my back every time I have to get him in and out of the back of the car in his car seat.
I've heard there is something you can do by disconnecting the terminal to the passenger airbag, but to make sure that the drivers airbag remains active, you have to fit some kind of resistor to the connectors
Anybody got any more info on this ??
Cheers,
Scott
  • Replies 13
  • Views 9k
I've never done it before mate but, if you are going to do it make sure to disconnect your battery before anything so the airbag ECU doesn't detect that you've disconnected the airbag(and to make sure you don't accidentally set of the airbag in your face).
You can get the resistors of eBay:
http://cgi.ebay.co.uk/RECARO-Universal-Res...=item518e576843
It's quite expensive for what it is, if i was you i'd find out what value resistor it is and i'd go down to Maplins and just get a resistor of that value. It shouldn't be more than 50p.
Hope that helps mate!
Ussy
I believe it can be deactivated via vagcom. (diagnostic software) Thats at least what autodata suggests but then again I'm unsure on the exact details of your car.
I'd imagine skodaboy (iirc) will know this so hopefully he posts in here.
Ian.
Ian.
Luckily, I have VAGCOM / VCDS but hadn't thought to look tbh.
I'll have a mooch tonight to see if there is an option
ok, can you fire up vag-com and go into the airbag module and tell me what the component number is please?
Will do mate, i'm at work at the mo so i'll do it tonight and post back then
Its ok mate..........
All sorted !
Cheers for pointing me in the right direction though...........
ah yes excellent, that would have been my next step after seeing the component number, go into airbags, adaption, channel 1, then write a 1 into that channel
fyi the other channel numbers relate to the other airbags (if fitted)
1 - front passenger
2 - front steering wheel
3 - passenger side airbag
4 - driver side airbag
5 - passenger belt tensioner
6 - driver belt tensioner
7 - passenger side head airbag
8 - driver side head airbag
disabling the passenger airbag should make this fault code appear in the airbag module, 01280 - Airbag: Passenger Side: Disabled, on some airbag ecu versions this will also bring on the airbag warning lamp on the dashboard which you need a login code to clear
1 - front passenger
It was quite good as it had a pre-entered adaptation code which just needed changing to disabled.
When I started her this morning, the airbag light on the dash flashed a few times (which I presume was related) then just went off.
You seem to know what your talkin about in reference to VCDS....... whats your background ? You work for VW ? ;)
1 - front passenger
Pust been told by somebody else that disabling via VAG-COM isn't enough, you apparently have to disconnect it too ???
no, if it's disconnected it will show an open circuit fault constantly which will light up the warning lamp permanently regardless of whether it's been disabled or not...
when i say you need a login code, what i mean is that whenever there is any fault code stored in the airbag module it brings on the warning lamp, disabling a airbag nearly always returns the a fault code like i mentioned above and the login code instructs the airbag ecu to 'ignore' that fault code which switches the warning lamp off.... like i said before it depends on which version of the airbag module you have fitted..
the flashing on startup is just telling you that it has a non-critical fault stored in memory..
there is one thing you need to remember about the airbag ecu too, you can only switch on or off any of the airbags upto a maximum of 50 times collectively before you get completely locked out.. at which point all you can do is have all of them active (by resetting channel 0 in the basic settings)
50 times ??? You havin a laugh ?
Which plonker designed that system ?
Don't suppose it matters, I'll just leave it off now till I sell the car.....
Where do you learn this stuff ?????
from too many years tinkering with vw's and skodas.. also i do have a fair few of the proper vw workshop manuals that i've.. ahem... "found" over the years too from some of the contacts i have that work for vw
