Cant access a dent!
I've been trying to straighten out my dent on my MK3, in the rear quarter panel on the driverside. However, we took the inside door card off and we cant access it because of metal panels and the body underneath the arches covers over the dent so there is no way to get to it, any ideas?
  • Replies 8
  • Views 1.6k
One of those sucker pad things which sucks it out from the outside might work. Not sure how much they are to buy though.
ye, i was gonna say what was said above.
i use them from time to time at work and they work wonders if your in a situation like you.
will keep my eye out :)
just use a kitchen since plunger, same principles lol.
Or I'm not sure what they're called but there's the things that like tack weld a pin and then the tool pulls the pin and then you cut the pin off, bit brief I know, take it too a body shop and get a quote :)
to be honest i was considering doing sheet metal over the top to cover it, this way i could make some wider arches possibly?
anyone done this yet?
sounds rather a bodge way of doing it. Either get a vacuum dent puller or use a slide hammer to pull it out.
Allthough I'm all for bodgeing, if your going through the effort to weld a sheet over the panel why not get a new panel and just weld that in
